Hi folks,
I'm needing to get new filter caps and a few other resistors and stuff for my mark IIB.
Some parts have been changed in the amp over the years,before it belonged to me and I want the amp put back to stock.The filter caps are still the originals.
The screen grid resistors were changed and I would like to have the original carbon comps put back in the amp.
I have been asked by MESA's distributor for the volts and uf from the caps but I can't see any info from just looking at them?
I also want the power supply dropper resistors returned to original carbon comps.
I would really really appreciate if someone could tell me what the values should be on the filter caps for the main filter caps and also the pre amp board Filter cap.
I also need to know what the values should be for the original stock screen grid resistors and power supply dropper resistors I need as I would like to source the parts needed myself and then the tech only has to charge for the work he does for fitting them etc.(He is fine with this)
Here is a thread with pictures of the amp showing what has been changed,and what is needed to return to stock. http://forum.grailtone.com/viewtopic.php?f=27&t=67930
Many thanks in advance.
