WaxCapacitor
- Joined
- Sep 22, 2023
- Messages
- 7
- Reaction score
- 0
Been scouring this thread for a couple years now and decided to join….
Recently sold a iic+ SRGX , and have pulled my HX out of storage to dial similar tones ….
Off the bat the HX has a “fizzier” and somewhat “duller” saturation on LEAD channel… whereas the SRGX had a more dynamic, raw , inspired saturation that I got used to. To me it boiled down to the pick attack, and resulting “feel”. I was able to dig in naturally and for all intents and purposes it was the best sounding iiC+ I’ve heard.
It was a SRGX iiC+ combo , that I switched out the EV12L for a ms-12. To be honest I wouldn’t mind if all ev12L’s were thrown off a bridge never to be found again. To me the completely neuter a iiC+ or iii .
I’m wondering if this phenomenon I’ve heard about recently of the filter cap values drifting over time from say 25uf to 10uf , or 5 uf. I’ve heard that as long as the dielectric is intact and the voltage capacity is still there, that a drifted filter cap can work fine.
I also wonder if the models with reverb may behave differently. If you’ve got a signal off V1A , routed to reverb driver and recovery , you are bypassing the tone stack and blending the 1st gain stage with the raw guitar sound. I would put verb on 1 , maybe 2 to blend signal with tone stack this way and also get a subtle spatial effect.
This was the best tone I got out of the iiC+ , as the lead channel and amp in general can be a little too dry for my tastes.
Lastly , the SRGX had original STR-15’s and OG 12ax7’s . I’ve scanned around and some say the difference is marginal between OG tubes and JJ’s (as an arbitrary example). I’m not sure I would concur. The STR-15’s had a focus and urgency that I don’t hear with other tubes . Right now I’ve got El Menco 6L6’s loaded in the HX , El Menco 12ax7 in V1- Amprex ax7 V2 - Amprex 7025 V3, and El Menco 7025 in phase inverter. Maybe overkill for 7025 in V3 ?
HX isn’t terrible , but definitely not yet inspired by it . I’ll throw new filter caps in to see if it opens the tone up, and probably stuff the HX chassis in a Mark iii cab (with ms-12).
After that , I can’t think of anything other than the happenstance of resistor/electrolytic values drifting from their original spec , into somewhat of a Goldilocks situation , or the STR-15’s are really just that bold.
Anyone notice this with a HX , SX, H, or S ?
****Im running a mesa 5 band in the FX loop of HX **** ….and I’m convinced it behaves exactly the same as a built in GEQ (Mike B endorses that observation as well) , so that isn’t of concern for the natural of my post …..
Thanks , sorry for long winded post
