Mark III 60/100 Purple Stripe Screen resistor help
nickp405
Hello, I'm restoring a 60/100 purple stripe 4-6l6gc tubes and I cannot find the stock screen resistor values for the power section. I have 4- 470ohm
resistors that I know are correct, but the others are 2.21k and does not seem correct. I measured them and they are in tolerance. Everything else Ive read says they should be 2.7 or 2.9. I cannot find the exact ones that are correct. I'm completely restoring this amp, and have installed new power tube sockets and Im using 470ohm 5 watt resistors. any help would be much appreciated. Thanks in advance!
470 is correct for an H (60/100W)- 2W CC typically or 5W like you have
2.7k is for the class A sockets (outer pair) of a simul-class (D) power section- same 2-5W
2.2K 1W carbon comps are for the grids
