Recently purchased a Mark V
jkennedy100
I play very heavy music. I must say that I am very impressed with the Mark V. It is so tight. It is unforgiving for sloppy players...but it is so tight for polished players.
I use a KFK MXR 10-band EQ as a pre-EQ. It is doing +6 500hz and +3 125hz (no volume or gain boost). This provides additional attack for high gain. The G Major in the effects loop sounds great...I use the G Major parametric EQ for extra kick - and a hint of delay to thicken the sound. I get a great distortion sound with this. No crazy distortion pedals, etc needed. Stock tubes are great.
Both the extreme and MKIV settings are very good for high gain. I love the 10 watt, 45 watt, and 90 watt switching capabilities.
The clean channel is amazing. Just add a little chorus to make it shine even more.
So much tone in this thing! I'm using an over-sized recto cabinet with stock v30s that sounds great.
FYI - the guitars have EMG 81/85 with the 18V mod. I highly recommend this setup for metal!
Hello jkennedy100,
Do you have some clips? I am curious about the eq boost in front of the amp...
I also have an EMG equipped guitar with the 18V mod, but find it less detailed, with less deep bass and high freq definition than my SD JB/Jazz loaded ones.
Best :) ,
Marcelo
No clips yet. I'll post eventually. If the EMGs aren't your preference, then you may like the Seymour Duncan blackouts. As far as pre-eq goes....soooooo much tone shaping can be done with pre-eq. I don't go without it.
Ace!
I use a similar same setup as you (pickups, but not modded) except i use my rig for post rock!
Don't overlook the mark 1 mode for high gain. The thickness is insane! 8)
Got mine about a month ago and been playin it thru a 4x12 RK cab. I have a 2x12 Vert on order.
My Les Pauls rock thru this baby, Strats....not as good.
