musicbox said:
no soul...a more correct analogy would be comparing an epiphone custom shop elite to a gibson les paul. both use the same pickups, the same electronics, the same grade of wood, and both are hand built in the u.s. the only difference is the little logo at the top of the headstock. there are those that can live without out, and those that can't. those that can, never think twice. they got the same guitar for less money.
you are talking to the wrong person about Les Pauls, ESPECIALY Japanese ones. Im a collector
Your analogy is bad, because either you dont know your guitars, and/or its not a good analogy PERIOD
1st, there is no such thing as an "epiphone custom shop elite"
You are refering the Epiphone Elitist line, formerly just known as Elite.
There is nothing custom shop about them, they are made in a factory by a company called Terrada. Some models were made by Fuji Gen Gakki, who makes most Ibanez guitars.
They DO NOT use the same electronics. American made, yes, but they are not the same.
The grade of wood is very debatable but it isnt the same. The sources are completely different. Also the elitists are multipiece bodies. Your average Gibson Lp std is a single piece body, unless we are talking about Norlin era models.
Also, Elitisits are poly finished, Gibsons are nitro.
So no, they arent the same.
With that said, I think it should be rather apparent that Im OBSESSED with detail when it comes to gear, cabs are NO different.
And I dont see why you want to try to push this argument considering you havent even tried a VHT?
