I have a Mesa Mark III Black Dot here, and upon opening it up to do some preamp tweaks i noticed..... mysteries! :shock:
Nothing too crazy really, but in addition to already being aware of the bias pot added (before i purchased the amp) - i saw something quite different in the power section. Let's just say it doesn't match the schematic -
While being decently proficient at soldering, i can say that i am no expert technician. I'm doing some of the cap mods listed on here for taming some of the fizzy-ness in the preamp section (C27, C30, C516, etc)... but i'm not well versed with the operation of power sections (other than how to drain caps, etc). For the sake of gathering data and learning more, i decided to post this on here and see what some the Boogie Board experts had to say.
From what i've been able to dig up this amp looks like it's been converted over to Pentode operation, seeing as no pins are wired together like the triode designs are. Would somebody be able to confirm this for me...? I just wanted to make sure it's done right and the values look healthy, even if the soldering job doesn't quite....
Notice how two of the leads from the transformer have been "taped up" (look where the zip ties and heat shrink tubing are). In regular Mark III's i noticed that each of these leads would be wired straight to pin 3 of each tube. Instead, it seems that only one of the green and one of the orange are used, while the other one is wrapped/taped up..... with the pins instead being jumper'ed across to it's neighboring power tube. Does this look right? Like does it match what say a Green Stripe pentode setup would be?
Also - since the knob is here anyways, i'd like to get the bias dialed in with my tubes as best i can. I've done the 1-ohm resistor shunt before, but heard there was an easier way with mesa's... measuring between Pin 3 and the center tap of the OT. Where is this on my amp? Things are changed so much from the schematic i'd rather just hear from an expert where best to measure from, based on these pictures... like which color wire would i be measuring from?
Any/all advice would be much appreciated. Im new to this forum, but have owned Mesas (DC-5, Mark IIB Coliseum, Blue Stripe Mark III) for several years now.... I'm very excited to start expanding more in the knowledge/operation of their design. Thanks!
