• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
FS: Mesa 20/20, ADA MP-1, Furman PL-PLUS, SKB 8U Rack
mrichman
Parkland, FL
Mesa Boogie 20/20 Power Amp
- 20 Watts per Channel, Dyna-Watt Power / 4xEL84, 3x12AX7
- Fixed Bias
- Independent Volume & Presence Controls per Channel
- Slave Out
- Fan Cooled
- $899.00 MSRP
ADA MP-1 MIDI Tube Preamp
Great for modding!!! See www.adadepot.com for details.
Technical data:
EQ: Bass: +/- 16dB center @ 180Hz Mid: +/-12dB center @ 600Hz Treble: +/- 16dB center @ 1.6kHz Presence: +/- 12dB center @ 3kHz.
Tube Complement: Four stages of gain using two, low noise 12AX7A/7025.
MIDI: Channel 1-16, OMNI, MIDI OFF, Program change: External 0-128, Internal 1-128, MIDI Mapping.
Chorus: Depth: 0 (none) to 10:1 Speed: 0.1 sec. to 10 sec.
Inputs:
Front panel: One 1/4" phone jack, high impedance (1 meg ohm) wide range input. Rear panel: One 1/4" phone jack, high impedance -same as front panel input.
Outputs: Two, single ended 1/4" phone jacks, Complementary stereo outputs.
Effects loop:
Send: Single ended 1/4" phone jack variable from instrument to line level. Max. drive on the send line is +19dBV.
Receive: Single ended 1/4" phone jack. Max. signal level is + 30dBV. Level: Provides 20 dB of boost or cut to the send/receive signals interfaces with low level and line level effects.
Headphone Out: Stereo 1/4" phone jack. Drives headphones of 600 ohms or more. Level: Provides full mute to + 17dB above internal signal level. Max. output +12dB.
Power: 120VAC, 50/60 Hz. Power consumption: 12 watts.
Dimensions: D= 10.5", W= 19", H=1.75" (1 rack space).
Weight: 6 lbs; 8 lbs shipping.
Furman PL-PLUS Power conditioner w/ voltmeter
- Maintenance-free surge suppression
- Series Multi-Stage Protection Plus (SMP+) circuit with extreme voltage shutdown
- LiFT (Linear Filtering Technology) with zero ground contamination
- 8 rear-panel outlets and one front-panel outlet
- 15-amp rating, with circuit breaker
- Meter for line voltage ranging from 90 to 128V
- Retractable LED rack lights with on/off/dimmer control
- BNC back-panel connector for gooseneck lamp with front-panel switch
- Master switch control of rear outlets
- Front-panel circuit breaker
- One rackspace
- 10', 14-gauge, heavy-duty power cable
- $245.00 MSRP
SKB 8U Roto Rack
The SKB Roto Rack 8U portable rack case is strong, lightweight, and stackable. This case includes large, molded-in handles, a removable lid, and a rear access door. SKB Roto Rack 8U Portable Rack Case Features:
- Molded, built-in handles
- Light weight
- Stackable
- Rackable depth of 17 3/4"
- $279.99 MSRP
All in fantastic condition, lightly played in a smoke-free home!!!
What are you looking for, for the ADA?
Or is this more of a "make an offer"? lol
It's $250 plus s/h...assuming you're in the US, I'll ship it however you like.
Thanks,
Mark
