• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
Dean Acoustic/Electric Bass and Bass Amp For Sale
verity38
Boston,Ma
I have a 100% Mint Dean Acoustic/Electric Bass, this bad boy has never left my house as a matter of fact it has never left my studio room. Here's what musicians friend has to say about it:
Features: 7.74
Quality: 8.09
Value: 8.91
Overall: 8.04
List: $524.99
Sale Price: $329.99
Plugged or unplugged, it delivers a big, full bass tone.
The Dean Performer Acoustic-Electric Bass Guitar gives you plenty of volume and response from its select spruce top on a mahogany body. Its cutaway body lets you get to the high notes with ease. And the 3-band electronics let you plug in and get the sound you want at higher volumes.
Dean Performer Acoustic-Electric Bass Guitar Features:
Select spruce top
Mahogany body
3-band electronics for easy amplified sound tailoring
Want a natural bass tone plugged or unplugged? Order this axe today.
I will sell this for $215.00 USD or best offer - I AM IN THE BOSTON AREA. BOSTON MASS
also for sale is a Crate BT100 100 watt mint Bass combo. This has never been gigged and has about 20 hours of use. I got it then decided to upgrade to a half-stack so it never got used. Here is what musicians friend has to say:
Features: 8.87
Quality: 8.69
Value: 8.92
Overall: 8.76
List: $549.99
Sale Price: $349.99
Product Information
A full-sized combo with pro features and a very friendly price.
With 100W, a 15" bass driver, and a balanced line out, the Crate BT100 Bass Combo Amp can hold its own in nearly any gig situation. It has 2 channels: a distortion channel with gain, shape, and level controls; and a clean channel with level, 4-band EQ, and an octave switch with level for boosting bottom end. Its XLR balanced line out is pre/post selectable. The CFS2 2-button footswitch is included for switching channels and kicking in the octave switch from the floor. Limiter, chromatic tuner, headphone jack, and CD inputs are also incorporated.
Crate BT100 Bass Combo Amp Features:
Crate 15" bass driver
100W RMS
Chromatic tuner
Input pad and tuner mute
Distortion channel with gain, shape, and level
Clean channel with level, 4-band EQ, and octave switch with level
Limiter
RCA CD input
Headphone jack
XLR balanced line out with level, ground lift, and pre/post EQ select
CFS2 footswitch included
Crate BT100 Bass Combo Amp Specifications:
Output Power Rating: 100 watts RMS @ 2% THD, 4 ohms, 120 VAC
Gain: Distortion103dB
Clean 61dB
CD Inputs 33dB
Tone Range:
Low 20dB @ 50Hz
Lo Mid 24dB @ 150Hz
Hi Mid 18dB @ 1kHz
High 32dB @ 10kHz
Input Impedance: 220k ohms
Maximum Signal Accepted: 15 volts peak to peak
Internal Speaker:
Type: Crate Custom Frame
Magnet 56 oz.
Voice Coil: 2.5
RMS Rating 150W
Impedance 4 ohms
Balanced Line Out Jack: 2 volts peak-to-peak @ full rated power w/600 ohm load
Signal to Noise: 65dB below full power, tones flat, gain and level @ "10"
Power Requirements: 120 VAC, 60Hz, 115VA
100/115VAC, 50/60Hz, 115VA
230VAC, 50/60Hz, 115VA
Size and Weight: 26-1/2" H x 21-1/2" W x 16-1/2" D, 69 lbs
*without casters
On top of all that, it sounds fantastic. Order today and play happy.
selling for $225.00 USD
if you want pictures or sound clips email me at [email protected]
I repeat all of thease are in Mint Conditions.
