• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
Pedal Purge - Neunaber, Catalinbread, Boss, and more...
robberns
Massachusetts
Finally went through my pedal closet and decided to move some nice pedals to make room for my clothes.
All prices include shipping in the CONUS, PayPal (via Gift only, please).
Local pickup can be arranged if you are in MA/NH.
See below for more details (including pics) on each pedal.
Boss CE-20 Chorus Ensemble $115
Catalinbread Dirty Little Secret MK III $110
ART Professional Parametric Tube Equalizer $85
The GigRig Humdinger Buffer/Isolater $100
GoGo Tuner Pedal $40
Neunaber Wet Reverb (Mono) $135
Classic Boss Chorus, 4 user-selected presets.
In great condition, can be battery powered or by 9V DC power supply (not included).
The CE-20 Chorus Ensemble is the culmination of over 25 years of BOSS chorus experience. This programmable chorus pedal not only models classics like the CE-1 and SDD-320, but creates entirely new Effects including chorus for bass and acoustic guitar. New "Brilliance" and "Ambience" knobs offer unprecedented realtime control over the chorus tone-making the CE-20 a pedal no guitarist should be without.
• BOSS' finest Chorus Effects ever offered in a compact pedal
• 6 chorus modes: Rich, Bass, Acoustic, Standard, CE-1 and Dimensional D
• Brilliance parameter adjusts "sparkling" feel of chorus
• Ambience control adds Reverb to chorus for greater spaciousness
• 4 User memories plus manual mode; stores all knob settings
• Stereo In/Out and Headphone Output
Catalinbread Dirty Little Secret MK III Overdrive pedal. Excellent condition, never put on a pedalboard.
Dirty Little Secret: At a Glance
• Complete redesign with two Marshall modes.
• Super Lead and Super Bass to suit your sound.
• Fantastic cleanup with your guitar's volume control.
• Ideal for stacking with fuzzes, ODs, and boosts.
• Exact tonestack circuits from SL and SB amps for true-to-amp response.
Technical Specifications
• 2.34" x 4.39" pedal
• Battery operation or 9v-18v Negative Tip DC Power
• 6 mA draw
The "Super Lead" mode expands the range of the DLS MkII with more gain available and more control over your tone sculpting with the addition of the midrange control while still enhancing the touch-sensitive dynamic qualities that make the DLS so great to play.. The gain range now goes from classic plexi all the way to modified JCM800 levels and can get even more raw and open than any previous DLS.
The "Super Bass" mode is a new voicing that gives you the tone and gain structure of a Marshall Super Bass (which is very similar to a JTM45 or JTM50/100). This mode was voiced to really hone in on that elusive in-between "not quite clean, not quite dirty" response that old tube amps were so good at getting. And it was specifically voiced to make fuzz pedals sound great.
Small footprint single-channel Tube Equalizer, 4-bands, balanced and unbalanced ins/outs. In excellent condition, includes manual.
Tube Equalizer
The Tube EQ from A R T is the world's most affordable tube-based parametric equalizer. The four-band Tube EQ is a precision frequency network designed to give you ultimate control over musical instruments and vocals like you've never heard before. Following our tradition of manufacturing world-class tube processing equipment, A R T completes the chain with an incredibly versatile and musical equalizer - the Tube EQ.
Like its predecessors - the Tube MP and Tube Compressor - the Tube EQ provides you with stunning musical results at a truly remarkable price. Whether you're an experienced recording engineer, live sound technician, or home amateur, you need at least one channel of high-quality studio equalization. Unfortunately, the EQ stages in affordable mixers simply cannot deliver the superior sound and flexibility offered by the Tube EQ.
When applying "radical" EQ, the Tube EQ's on-board tube actually improves the sound by gently smoothing frequency peaks. The frequency bands of the Tube EQ overlap and the two mid-bands sweep from 20Hz to 20kHz, meaning that any trouble spot may be addressed without leaving a "hole" in the audio spectrum.
TheGigRig HumDinger Isolater buffer pedal, excellent condition. Eliminates ground loops when using multiple amps and can also drive long cable runs.
Must be powered by 9V DC Power Supply (not included).
THEGIGRIG HumDinger
If you use 2 amps, mains powered effects, or need to drive long cables, the HumDinger is essential.
The Humdinger was designed to eliminate earth loops in audio equipment by isolating the second output with a high quality audio transformer.
" The Main output is buffered using our custom designed 1:1 class A buffer design guaranteed not to mess with your tone.
" The Isolated output uses a high quality audio transformer to the best signal possible.
" The isolated output also features a PHASE switch, so you can get rid of any phase problems between two amplifiers.
" Both outputs will drive long lengths of cable so you don't need to worry about the distance between your pedal board and your amp.
" It's impossibly small and will fit on even the smallest of pedal boards.
Earth loops are a common complaint. As soon as the ground on your gear has more than one main route to earth, you have the potential for an earth loop.
The best and safest way to get rid of an earth loop is to isolate the ground that is causing the hum.
Using the HumDinger to get rid of earth loops is easy. If you use 2 amps all you need to do is stick the HumDinger at the end of your effects chain. Your main (buffered) output goes to one amp, and the isolated output goes to the other. Your earth is consistent through the main output but isolated through the isolated output.
Using a mains powered effects pedal, simply place the HumDinger in the chain after the mains powered effect.
The Mains powered effect is your main ground and the ground from the amp is isolated.
http://www.thegigrig.com/acatalog/HumDinger.html
GoGo Pedal Tuner, brand new, never used. Great for guitar or bass.
Can be battery powered or powered by 9V DC power supply (not included).
Features:
• True-Bypass
• Chromatic tuning
• Daisy-chain with other pedals
• Metal chassis
• Durable stomp knob
Tuner Type: chromatic
Detection range: A0(27.5Hz) - C8(4186.00 Hz)
Detection accuracy: +/- 0.5 cent
Display: bright, extra large, two-color LED screen
Power: 9V battery, or 9V DC
Power draw: 25mA
Dimensions: 4.92"(l) x 2.91"(w) x 1.57"(h)
Weight: 12.48 ounces
Finish: Gogo orange
Casing: metal chassis
Neunaber Mono Wet Reverb, in excellent condition.
Sent back to Neunaber for a mod to the Mix control to give it finer control.
Simple yet surprisingly versatile, the Wet™ Reverb has been described by users as "organic", "haunting", and a "choir of angels"—seriously, we can't make this stuff up.
Features
• Simple two-knob adjustment results in a surprisingly wide range of sounds
• Buffered trails bypass
• Fine Mix knob adjustment from "just a touch" of reverb to 100% wet with no volume loss
• Variable Headroom Control*allows line-level use for many applications (see User Guide)
• Very high input impedance: no "tone suck"
• Analog dry signal for low noise and zero latency
• Small footprint
• Made in USA
