Mesa High Gain Amp Switcher
MesaMad1378
Post by MesaMad1378 » Thu Dec 29, 2016 2:50 pm
I have just bought a Mesa HGAS and was wondering if anybody knows what the voltage supply is?
2:90, 2:100, SUS-4 16ru Case,
And other stuff!!
ReidarNikolai
Re: Mesa High Gain Amp Switcher
Post by ReidarNikolai » Fri Dec 30, 2016 6:16 pm
It should say on the back.
However - I am in Europe - bought one with US voltage and there was no trouble changing the voltage inside the HGAS.
You need to change a resistor and move a couple of jumpers inside the unit but it is well marked.
Let me know if you need the specifics - I communicated with Mesa Boogie about this - and my HGAS works as it should.
Thanks
ReidarNikolai
MesaMad1378
Post by MesaMad1378 » Tue Jan 03, 2017 8:23 pm
Thanks for that, as you sent this I found out how to do it.
Remove the 2 110v jumpers, put in the 230v jumper and swap the 110v MOV with a 230-240v MOV.
And other stuff!!
ReidarNikolai
Post by ReidarNikolai » Wed Jan 04, 2017 4:00 pm
Yup - that is right.
I found the MOV´s at Mousers BTW - if you have a hard time finding them at home :)
Reidar
MesaMad1378
Post by MesaMad1378 » Sat Feb 25, 2017 4:57 am
Cheers for that, I bought 20 or so when I converted my 2:90 to 230v. Pretty easy to do really, took longer to get the cover off and on than to actually do it.
And other stuff!!
