Mark IIC+ Reverb switching question
deskman
Post by deskman » Sun Jan 28, 2018 7:48 pm
I have a IIC+ with reverb only.
When I plug a regular TS latching switch into the jack on the underside of the amp, switching it on and off just makes the reverb go between where it's set and then a little quieter. Not really turning it off.
Do I need a TRS jack on the switch?
My understanding is that the amps without GEQ just used a TS cable to switch the reverb.
Anyone been down this road?
'in order to realise our creative visions, it is essential that we develop the craft of our instrument' - john petrucci
darkbluemurder
Re: Mark IIC+ Reverb switching question
Post by darkbluemurder » Mon Jan 29, 2018 3:45 am
I can check with my Mark III that also has reverb. I never tried switching the reverb as I mostly set and forget it. I will report when I get around to it.
Cheers Stephan
deskman
Post by deskman » Sun May 06, 2018 6:31 pm
Just thinking now - I might need to use a TRS and have the REV closing on the ring
lovetoboogie
Post by lovetoboogie » Sun May 06, 2018 8:49 pm
A TS will do...what you have is the reverb circuit where the footswitch control doesn't turn the reverb on and off...it's actually a reverb pad of sorts. It lifts/inserts a series resistor on the reverb recovery tube cathode. This is the bain of all reverb complaints on late IIC+'s and Mark III's as well... A simple rewiring of this tube opens the reverb right up and will give you a true on/off.
