espboogie123 said:nismofreakish said:I was thinking about this earlier today... I run my Boss Acoustic Simulator AC-3 in front of the amp and use it only with the channel 2, and to acheive an even volume with clean and acoustic, I must run the level at 80% on the pedal. Could it be the reason? I was doing the same thing before when I was using my Jazz Chorus for my AC-3 for my cleans.
Not sure how much signal boost that ac-3 gives, but roadster's get boosted by all sorts of pedals with no problems. Rectifiers are boost wh0res. I boost my lady with a maxonOD808 in a 4 channels when or if needed. Giving a strong acoustic clean signal could push a weak pre tube past its limits so being a tube problem is a small possibility especially with them being shipped with mass produced JJs. Other than than, something internal prob tripped out.
+1kick6 said:Something interesting to note is that he uses that AC-3 ONLY on channel two. So yes, it could theoretically be a problem with the pedal. He needs to plug directly into the amp to rule this out.
nismofreakish said:Just to be sure... yes I use my AC-3 only with the channel 2, but the pedal is in front of the amp so when I use my other channel I switch it off and the signal still does pass 'cause I don't have any problem with the other 3 channels.
nismofreakish said:remove it... you mean the time to make some tests?
espboogie123 said:V1 A = First Gain Stage (Input Stage)
V1 B = Second Gain Stage
V2 A = 3rd Gain Stage Ch. 1 & 2
V2 B = 3rd Gain Stage Ch. 3 & 4
V3 A = 4th Gain Stage Ch. 3 & 4
V3 B = Tone Stack Driver Ch. 3 & 4
V4 A = Reverb Return Buffer
V4 B = Reverb Send Driver
V5 A = FX Loop Send Driver
V5 B = FX Loop Return Buffer
V6 A&B = Phase Inverter
From the actual tube assignments... v2 would theoretically mess with ch1 AND ch2 on side A. Either way, swap the tube, if not then your prob lies somewhere else like said before.
nismofreakish said:If the pedal kinda worn out the preamp tube, it will work out at first with the new preamp tube. I'll just find out later if it blows again...
I think, in order, I'll try my amp once again (haven't played it 'til the gig), see if it's still "broken", if so I'll remove the AC-3 from the chain, if there's no sound, I'll turn off the amp and try replacing the V2 tube. Again, if it doesn't work, I'll try the V1... (anybody could give me a link for the preamp tubes' fonction and location? It's not in the pdf manual, thx!).
If after that it still doesn't wanna work... I'm screwed... it's gonna be tech time
After 1 1/2 week of playing... it's a shame.
Enter your email address to join:
