94Tremoverb
- Joined
- Dec 5, 2009
- Messages
- 1,340
- Reaction score
- 0
I'm getting a serious resonance problem with a Rectoverb combo (series 2) - when I play a palm-muted C power chord on the red channel at anything above medium volume, there is a loud after-resonance 'bloom'. It's not a microphonic tube, or anything else in the amp section - eliminated by running the chassis out of the combo with a long speaker cable. The trigger frequency changes to E when the combo is run with the back off, but the after-bloom sounds the same (C). When run with the back on, you can feel a huge blast of air coming out of the port when it happens, and not at any other time, so clearly the speaker is working massively too hard at that frequency.
I've also tried replacing the speaker, both with another Black Shadow 90, and also with a Classic Lead 80 which is closely related but I hoped might be just different enough to either cure it or at least change the problem frequency, and at worst prove it was the speaker... no change. I also tried running the amp with EL34s just in case... no change. And it's nothing to do with the reverb - it's turned off.
Has anyone else found this? Is it a problem with the speaker type, or some sort of bad interaction between the power stage and the speaker? I haven't tried other speakers yet, but I don't want to if I can avoid it because it sounds so good otherwise. I also don't want to change my settings! It sounds exactly how I want when it's not doing this.
