212Mavguy
Have to say that I need to thank Dan Torres for his book, Inside Tube Amps. I borrowed it from a luthier friend who had it sitting on a shelf unread for quite some time. In the past I had done some preamp mods in my lowly Silverface, increasing the value of the cathode bypass caps for each of the 12ax7 sections and also for the power tube cathode bypass. I had gone too far with increasing the values for the 12ax7 halves, particularly the second half. The reason for the mods was to replace the 3 exploded stock 25/25 caps. The previous owner had a habit of boosting the you know what out of it to push for stage volume. I had gotten the amp secondhand for 75 bucks in poorly operating condition, low volume output and the speaker had a rub.
Although the amp now sounded huge, it had become a bit woofy from my overdoing those caps After taking the second stage 12ax7 cathode bypass cap value down and slightly reducing the value for the power tube bypass it opened up more in the upper middle and top. I presently use it as a head into a 16 ohm 2/12 JBL g125 or 2/15 JBL g135, because after changing out both trannys, especially the huge, oversized new output tranny it became too loud for it's tube health, they rattled around too much from the speaker in the cab, I had tried a 10 inch Peavey Scorpion. The stock POS speaker was toast. The next mod was to increase the value of the resistor going from the bass pot to ground, think that stock was 6.8k, now it is 10k. Have a more likeable mid content now. Will need to go shopping for some more caps for the pre next. Will be taking both sides of the 12ax7 down more, especially the first half. Right now with the 2/12 cab it gets too loud on stage with just a 6v6. It can run 6l6's and el34's because it now has a fixed/cathode bias switch and fixed bias pot. There is just enough coming out of the main tranny to run a 6550, but I have other amps for that kind of wattage. Right now it is a wolf in sheep's clothing. After further voicing in the pre I am confident it will open up even more. Next will be some adaptors to experiment with a diffferent preamp tube (Raytheon 5755) and also try a Bendix 6384. I have an 18 watt boutique that runs Bendix 6094's. That amp sounds spectacular.
Without the book I would not have known what to do. A bit spendy but worth every penny.
