McBarry
OK, so I'm comparing my IIB's, and notice one of them DROPS volume when the gain boost on m/vol is pulled..
I check the other one, and then check the IIA and yep, they both INCREASE gain when pulled..
Hmmnn, what gives..
Discounted the switch as culprit and also checked shorting between contacts, not the gain f/sw jack, not the 33k resistor or the .003 cap..
"What the hell is it", I'm thinkin'...
Finally desolder the switch on 2 amps and confirm the switch is backwards internally, ie: pushed in should be closed and pulled should be open.
BUT on this little sucker it is CLOSED when pulled, and open when pushed.
Thus when knob is in, there's max gain and virtually no tone controls, when pulled the amp is quieter and the tone controls work nomally..
How bizzare.....
Hmmnn, what gives..
How bizzare.....
