mark V 90 watt fx loop doesn't work
rmarton123
The FX Loop isn't recognizing the effects I place into the FX Loop. I have a Delay and reverb pedal and when I turn the fx loop on from the footswitch I get no delay or reverb.
Loop is turned on in the back and the Level knob turns the level up and down as it should but the loop sounds like it's a parallel loop with the mix level turned all the way down. Thus there's no delay or reverb coming through.
Just tested it again this morning. The effects loop light doesn't turn on. I haven't tried the other tests you suggested
