How to avoid incoming change control instructions
CeciltuckyAxMan
Am using a Behringer FC1010 and G Major 2 with the JP-2C. Expression pedal sending instructions to the G Major is using CC 27, which also controls the Shred function on the JP-2C. How do I keep the FC1010 and G Major talking to each other but stop the messages on the expression pedal going to the Boogie? Is it different midi channels? Everything is set to Omni currently and I'm a novice at complex midi. Thanks!
Sounds like the G Major 2 and the JP-2C are both set to channel 1.
Typically the way you deal with what you're trying to do is to assign the G Major 2 to one midi channel and the JP-2C to another midi channel.
I'm guessing that the behringer has to do a couple of different things here:
- Send commands for the G Major 2 only
- Send commands for the JP-2C only
- Send commands intended for both the JP-2C and the G Major 2
If you keep the G Major 2 on channel 1, and set the JP-2C to channel 2, you can set the expression pedal to use CC27 on channel 1, and whatever other pedals/switches you're using to control the JP-2C can be set to channel 2.
That way the expression pedal messages will only be going to the channel the G Major 2 is listening to and they'll be ignored by the JP-2C.
I don't know if that's helpful or not.
-Daniel
