nomad100hd
So along with my master volume not muting output at zero, when I mute my m13 in the fx loop it's not muting the amp. Yes fx loop is turned on... Is this normal?
pivot said:Mine does the same thing I believe it is because the effects loop runs parallel with the amp. The best way to mute the head is to have a tuner or a pedal to mute the amp from the input (Front of the amp) not the effects loop.
Enter your email address to join:
