I think you are looking at this inside out,kind of."So a higher plate voltage will cause the maximum current draw in mA to be lower (i.e. indirectly proportional)".Your plate voltage in a given amp will vary as you change the current draw.The plate voltage isnt "adjustable",your bias voltage or current draw are.Lets take your MKIV for example.Mesa tells you it is not adjustable,that is not the case.For years many amps were made like Mesa with a fixed resistor setting the bias voltage,when you changed tubes,you changed that resistor to adjust your bias.But in the case of a modern MKIV if you have 470volts on the plate with a set of tubes that are drawing lets say 24ma's and you change to a set of tubes that are drawing 35ma's your plate volts will drop some.Or if you were to keep the original tubes and adjusted your bias voltage so the tubes would now draw 35ma's the plate volts would drop as well,see where we are going here?To use your Bias Rite,without using an adjustable bias mod,what you want to do is,get a set of tubes with an unknown "grading" lets say a random matched pair of NOS RCA 6L6GC's.You would install the tubes,with your bias rite set up,see what the plate volts are and the current draw.You multiply your plate volts times the current draw,using the above numbers 470v times .024 amps equals 11.2 idle watts that is a "safe" idle for those tubes,somewhat cold though,class AB1 you would want to see about 20 idle watts.If you are not going to get into adjusting the bias,the best you can do with your bias rite is to check to verify that whatever tubes you are using are "safe",which in my opinion is not always the best.You will never see a stock Mesa amp idling 6L6GC's at 20watts.If they set the amp to idle that hot and then sold you a set of their "pre-graded tubes" that turned out to be hotter than expected you could fry something,not very inducive to selling tubes if they have users frying their amps,eh?
