Interesting. I looked over the schematics of the CH2 and did not see anything that would result in Crunch from cutting out. Many of the relays or switches may have some commonality with edge and Mark I that are also used by Crunch. There is one relay that has a triple pole Double throw labeled as RYM5 with contact set A, B and C. I only assume it is one relay and not a few of them. If for some reason the RYM5 relay is not making full contact when the Crunch mode is enabled, the contact set B (RYM5B) could potentially disconnect the output from V2. Hopefully it is not a mechanical relay issue. All other relay contact sets or switch connections were shared with edge or mark I and did not have the potential to disconnect the circuit path. If what others have suggested do not fix the issue, it may be time to have it looked at by a tech.
