visualrocker69
Just wondering because I came upon a possible trade for my Bogner XTC.
gts said:Yes but they no longer have the Simul OT's from that era (the SC-562019B was used on the early C+'s and the 562003 OT [which has the exact same specs] was used on later C+'s and MK III's). They likely only have the 565004R1 OT which was used in later Mk IV's.
igfraso said:Get the 60/100 Mark IIC+, run it on 100 watt and connect the 8 ohm speaker to the 4 ohm jack. According to Mike Bendinelli, this is the best way to get close to the SimulClass sound on a 60/100 watter.
gts said:Get a Mk III Simul put it in Class A, then slave the 60/100 C+ into it.visualrocker69 said:Doesn't help me if I wanna run it with EL34's in the class a slots! :|
Might be cheaper than doing the simul upgrade :wink:
You may find you like Class AB better in a Mark series amp. Fwiw Class A is not quite true Class A in a Simul
Enter your email address to join:
