I am not familiar with the Sovtek 6L6GB,but if it is a true 6L6GB it should not have over 360v on the plate.You did not say what amp you are planning on using these tubes in.If the amp has more than the specified volts at the plate or puts out more than 35-40watts you should replace them with the same 6L6GC's that were in it.I know Sovtek says their tubes will stand more plate volts than NOS tubes of the same designation,I believe this was a claim they made of their 5881's at one time.If they are selling tubes designated as 6L6GB but say they can put out more watts or take more volts then why not call them GC's?True 6L6GB's should not be put in a circuit designed for GC's.They may not blow right away but they wont last very long,and most likely will go south when you crank the amp.Most tubes will be able to withstand more than the design values stated in tube manuals,but many wont.I wouldnt use them.
