240V Power transformer question
sheeny
Hi Boogie people,
I have a question regarding the pending 110v to 240v PT conversion of my Lonestar Special. (actually two, but I'll get to the second one in a minute).
I have successfully completed this procedure on two previous amps with no problems. I just want to check this one first.
I have all the cables accounted for with my Mercury Magnetics replacement except the 110V primary cluster has a white cable with a black stripe as well? Is that necessary? I have the primary black (MM 240v PT black?) and a white (MM 240v Violet?) covered I think, as they seem to trace to the switch & supply input etc... so I'm guessing they are ok?
I have attached a 4 page pdf ( hi res images) URL if anyone can assist.
http://users.tpg.com.au/9876/Lonestar_110v-to-240v.pdf
OK, second question...
I also want to use high quality spade connectors (or similar) and heatshrink them instead of soldering directly to the board. That way I leave the original board connections untouched and then the original 110v PT can be replaced quite easily if required. Is that a wise move?
Looking forward to some helpful comments!!
John.
OK, all good.
  • + White with black stripe is redundant.
    + Black is active (Violet on replacement MM PT)
    + White is Neutral (Black on replacement MM PT)
Correct me if you believe I am wrong.
Over and out :)
