electric mayhem
- Joined
- Jan 13, 2018
- Messages
- 437
- Reaction score
- 193
I'm hoping some of the plus officiandos or even comancharos can chime in on this "barn find".
Can someone let me be lazy and list the IIC+ stages? It is my understanding that V1 is the clean gain and V3 for lead gain and V5 is of course the PI. That leaves reverb on V4 along with the loop which I'm guessing is V3 and V4 unless it was the reverb that uses separate tubes for out/in. It also leaves V2 for the suspected tone stack and it is that theory on V2 that pertains to my best guess at the extra triode use.
As you can see the added 9-pin socket is not original by color. Only 1 triode is being used.
On the board side two things stand out for the +1 (pun intended). The grid appears tied to the DC rail on the board so it's not a typical gain stage and the coupling cap is on the cathode. The other thing of note is that if I have the signal path in my head correct it is feeding into the grid of what I think is V2A.
All that said, does this mean we are looking at a cathode follower to buffer a clean gain stage for a high performance driving of the tone stack given the lower impedance going into the TS?
I would almost think a cathode follower would be better served on the lead channel but putting it on the front end effects everything down river. I haven't looked at the original stages well enough yet so there may already be a cathode follower somewhere in the amp.
I was told this amp is blowing fuses. None of the caps are shorted. The power pin sockets looked stretched to me and after my recent experience with a rectoverb cutting out and spitting at me I can't help wonder if the pin sockets are the low hanging fruit.
