• If you have bought, sold or gained information from our Classifieds, please donate toThe Boogie Board and give back.
FS: Sold
plan-x
Kalifornia
New offerings posted 7-12
SD-1 Monte Allums GT mod $75. Sold
MXR-120 auto Q (auto wah) $85
Looper (TB) $45 paypal'd & shipped conus.
SD-1 has 2 toggles. One for asymmetrical/symmetrical clipping. The other toggles a gainier/brighter mode. Also includes the OPA2134PA Burr Brown op-amp. The socket can interchange whatever op-amp you want. This pedal blows away a stock SD-1. Sold
BYOC OD2 was built to Mosfet spec and has a Mosfet clean boost switch. The Mosfet mod makes this TS clone very amp like. Although it's a TS clone, all the circuit components are high quality with improved values making this a really killer pedal. Toggles (3way) between mosfet/none/silicon diodes, clipping options. Other toggle (3 way)does bass boost EQ options. Also has a couple of internal trims for gain and vol. This pedal is TB pedal with a socketed op-amp to swap out your IC's. Runs on 9v batt/or power supply.
MXR 120 Auto Q (Auto wah) plenty of adjustments to get lots of E filter effects.
Looper (true bypass) I built this to GGG specs. You can switch to a whole different set of pedals and back with this cool little looper. Doesn't even need a batt/power supply(neg tip 9v) to work, unless you want to see the LED light for loop engaged function.
