brain fart.. 2:90 with recto cab impedance question
rispsira
Hi all!
So my setup has been pretty simple as id take each 8 ohm output of the 2:90 to two seperate mesa cabs (each output going to the correspondant 8 ohm input on each cab) and did the same thing with heads in stereo etc.
Now i have a small setup at home as well and i just wanted to try the 2:90 in stereo with a SINGLE recto cab, and yes i know its not the same but i have some stereo presets i wanted to listen to.
So on the recto cab in the back you can go stereo using the two 4 ohms inputs.
I used to do that a long time ago but i completely forgot how (need to learn about impedance again LOL)
So the 2:90 has 2 seperate 4 ohm outputs on each side.
Should i just use one of the two 4 ohm outputs on channel A -> one of the 4 ohm inputs on recto cab, then
one of the two 4 ohm outputs on channel B -> the other 4 ohm input on recto cab
