First of all, hi there I'm new to the Boogie world but have been reading a lot of interesting info through this forum for a while that has been so good for me to get a good knowledge specially about this great Studio Preamp
I'd like to ask you how do you put you FX loop level when you connect the Studio Pre to a power amp using the FX send instead of main/recording outs.
I run my Studio Pre through an (old too) Fifty/Fifty power amp, but I do use some effect pedals between the fx send and the power amp, these stomp boxes are basically an ISP Decimator G-String and some other time based pedals like a Memory Toy f.ex
At the end of the chain I've got a Fender mini ABY box with the purpose of duplicating the signal that then goes directly to the power amp with 2 cables
So I wonder if there is any problem by running the FX level toggle set as LOW or LINE, which should I better use? Can i blow any pedal by running it in LINE level? Is it bad for the power amp to use one or other level from this toggle?
Any suggestion would be really apreciatted, once more thank you guys for putting a lot of great info into this board, it helped me a lot for sure
