KingPetrucci said:
Authorized Boogie said:
If you're not using the phantom power feature, you only need to use a 5-pin cable. Thanks!
I'm sure my foot controller is no need the phantom power
but I want to know the triaxis 7 pin, which unit is for phantom power?
thank you so much
From the manual:
PHANTOM POWER: The coax power jack above the A.C. line cord can provide power to a Midi foot controller, through the 7 pin Midi
IN jack. This is accomplished by connecting an external A.C. to D.C. power
adapter of correct voltage and polarity for whatever type of foot controller
you are using to the coax jack on the rear panel of TriAxis.
Connect a 7-pin DIN cable between the Midi In jack on the TriAxis and the
Midi Out jack on the foot controller. This negates the need for a clumsy power adaptor on the stage.
NOTE: 7 -Pin DIN cable will not fit into 5-Pin DIN jacks. Check to see that your foot controller accepts 7-Pin DIN cables and is wired
to accept Power in this manner...and of the proper voltage match to TriAxis’ phantom power output.
