Just wondering, if you use a boogie power amp and only run 1 cab, is there a way to bridge the amp so you get all the wattage out on cab?
Or is it simply a, use one side of the amp if you only use on cab situation?
I have been debating getting a boogie pre, not sure which one yet. But I was curious what the deal was with the power amps.
Any help would be appreciated.
