im using a triaxis v2 and a older 2:90. it seems that the 2:90 i recently purchased used is causing a hum from channel b. no matter what cables i use or what channel on the triaxis i use to feed the signal into the 2:90 channel A sounds fine but channel B has a hum. tried using the ground lift to no avail. tonight i'm going to try swapping the tubes around to see what happens.
anyone else have any ideas for this?
