Hi, I'm new here and I'm just looking for a little help with getting my Nomad 45 2x12 up and running properly. Last week it road in the back of truck to a friends house for some practice. For some reason the Input knob or the tube that controls the input levels is having some issues. When adjusting it it seems to only want to go to a very loud volume or a very quiet volume. Lots of static when adjusting the knob, but no consistent change in volume level - it will just jump from loud to quiet when turning it up. I'm not sure if moisture or cold air form riding in the back of the truck would have done me in of if it is just a bad tube. Any help would be very appreciated. I tried searching the forums and didn't find much help. I should note too that I've tapped each tube when it is on and i don't hear any crackling or noise. The problem occurs with every channel and seems to be only effecting the output. Could it be the knob itself as the problem? Perhaps it got bumped when it was being carried in?
Thank you
Thank you
