B blue-moon Active member Joined May 10, 2012 Messages 27 Reaction score 0 Apr 10, 2017 #1 Those with Mark V heads... when you move the head around and say place it on top of a cab, do you hear a slight rattle. I assume it is the springs in the reverb tank. just want to make sure one of my springs isn't loose.
M mace Well-known member Boogie Supporter Joined Feb 2, 2014 Messages 502 Reaction score 100 Location USA Apr 11, 2017 #2 That's probably normal. When transporting in a car you'll hear the springs rattle a bit once in a while. Other amps do it too. If you're not hearing anything odd when playing with reverb on, the springs are fine. Regards, Mace
C Cathode Member Joined Feb 9, 2017 Messages 7 Reaction score 0 Apr 11, 2017 #3 Perfectly normal , i have never had a amp with a spring reverb that didn't make that sound when bumping it around.
Z zem100 Member Joined Oct 13, 2016 Messages 11 Reaction score 0 Apr 11, 2017 #4 Same here, was on a bumpy dirt road and it sounded like a tin can banging around. My Marshall did the same.
B blue-moon Active member Joined May 10, 2012 Messages 27 Reaction score 0 Apr 12, 2017 #5 Thanks guys.
