Lef T said:Title basically says it.
Is the reverb pre or post effects loop?
BlakemoreMusic said:Lef T said:Title basically says it.
The reverb is pre fx loop on the mark V. I'm not sure why Mesa designed it this way, (Im sure there is a good technical reason), but its a buzzkill if you run a volume pedal in your fx loop.
The Volume pedal will cut off the tails of the reverb.
Lef T said:BlakemoreMusic said:Lef T said:Title basically says it.
That's interesting.
I'm running a delay in the loop.
Would be better having the reverb running after the delay
Enter your email address to join:
