jnoel64
I found an old thread containing a "master list" of compatible power tubes for the V. In that list, 6V6 tubes were listed as being compatible as long as Variac power was used. I also saw a combination of 6L6 and 6V6 (the V's as the inner pair) that also called for variac power and never using the 10 watt mode.
My question is: Has anyone here tried 6V6 power tubes in their V? Doesn't matter if all 6V6 were used, or if paired with the 6L6 as mentioned above. If so....how did you like the results?
