SOLD: Mesa ElectraDyne Short Head in Black
For you guys across the channel. Boogie Only.
Chester
Post by Chester » Tue Feb 20, 2018 5:59 am
Guys
Reluctantly putting up for sale a Mesa Electra Dyne short head in standard black. This amp is in as new, unmarked condition, and in perfect working order. Comes with footswitch and cover. Currently running with Mesa 6L6's as standard, and preamp glass is quiet as a mouse
Offers a simple easy to use layout, 45/90W, with 3 modes - US clean to Marshall growl in LO / HIGH available at the tap of a footswitch. I've owned 7 Mesa rigs, and this amp has been the easiest to dial in, and most satisfying for medium gain tones and response for classic rock. Not a metal amp, but loves pedals, and is equally at home with hums or single coil pups
What Mesa says
Keep It Simple... Without Imposing Limitations.
Introducing the Electra Dyne™. An easy-to-look-at, simple-to-use amplifier that has way more TONE than you might expect hidden artfully behind these six knobs and a switch.
Deeply rooted in the Best of the Brit lineage, the Electra Dyne takes modified English gain sounds and sorts them into LO and HIGH regions. These two choices are combined with a retro-minded, American-voiced clean “channel” and linked to one mini-toggle that gives you three of the most classic sounds in Rock and Roll on one switch!
FEATURES
Simul-Class™ Power Tan Grille Amp (Patents 4,532,476 & 4,593,251) featuring a 45/90 Watt Power Switch that incorporates concept elements from our Patented Multi-Watt™ and Duo-Class™ technologies (Patent Numbers 7,602,927 & 7,173,488) providing two power and two operating class options: Choose 2 power tubes operating in time-honored Class A/B producing 45 Watts or 4 tubes running in Mesa’s legendary, Patented Simul-Class Power that blends the best of Class A and Class A/B simultaneously to produce 90 Watts of pure tonal magic / 4x6L6 (or 4xEL-34), 7x12AX7
Bias Select Switch (6L6 / EL34)
Fixed Bias for Consistent, Maintenance Free Performance
Single Channel simplicity with the performance versatility of a Multi-Channel amp through 3 Footswitchable Modes (Classic Boogie Clean, Vintage Low Gain, Vintage Hi Gain)
Channel Control Features: Volume (Gain), Treble, Mid, Bass, Presence & Master Volume
Clean Level Control
Gain Trim Switch
Slip Cover
All-Tube, Long Spring Reverb with Auto Reverb Defeat Switch for Vintage Hi and Lo Modes (Defeat Mode removes Reverb from Vintage Hi or Low Modes but retains Reverb on Clean Mode – Normal Mode applies Reverb to all Modes)
Reverb Hard-Bypass Switch removes entire Reverb Circuit from amp
Fully Buffered FX Loop w/Automatic Hard-Bypass to completely remove when not in use
Slave Out w/Level Control
External Switching Jacks for Vintage Low/Hi (Clean is default) & Reverb
17” Aluminum Chassis (rack-mountable option available)
2 Button Footswitch (Classic Clean, Vintage Low/Hi)
Manual available here: http://www.mesaboogie.com/media/User Manuals/electraDyne_100917.pdf
£945 + insured shipping, depending on location
Please pm me for pics, and any questions you may have
PRS 2 Channel 50
Carol Ann Triptik R
Carol Ann OD 3R
Carol Ann Tucana 3R
Carol Ann 10th Anniversary
Redplate Aurora 34
Marshall Anniversary 4X12
PRS 2X12
