gregrjones
- Joined
- Aug 15, 2007
- Messages
- 63
- Reaction score
- 0
I've read posts about those of you using the Yellow Jacket adaptors using one pair of EL84's with a pair of 6v6's, but I was curious if any of you have tried using all 4 YJ EL84's with this amp?
A second question: I've been using my LSC with YJ 2 EL84's (outer pair) and 2 6v6's (inner pair), but if I keep both channels of the amp set to 50 watts, am I correct that the inner pair doesn't even matter?
Because I read that when the amp is pulling less wattage, the ideal speaker ohm setting should be 4 ohms instead of 8, I have been hesitant to set the amp up traditionally so that the clean channel is set at 100 watts and the dirt channel at 50 watt....
