EL-34 tube in my Stiletto Trident Head
Posted: Tue Apr 22, 2014 11:03 am
Hi-
My former user name was TTSTWO. < For some reason I was not able to reset my password and my user name was not attached to my email address, anyway, not the reason I'm here.
I have a Stiletto Triden Stage 1 I purchased back in 2009. Only really crank it on the weekends for a couple of hours per night so I'm not burnig through tubes like some of you folks that gig a lot.
I make a habit of powering it up while I'm standing behind it to watch the tubes light up. Well, Saturday night I didn't and proceeded to play for a 1/2 hour or so. Later, I noticed that one of the power tubes was dead, not glowing at all, sound and volume level were not compromised. I flipped the power off and pulled the dead tube out to inspect and get the color code to order a new matched set. I put the tube back in, powered it on and now it works. ? WTF ? It glows perfectly as if it was never dead.
Anyone run across this ? I will keep a closer eye on it from now on, anyone have an explanation ? The tube was not loose and in the 5 years I've owned the amp, I've never had to pull or check the tubes.
Thanks, TS
Thanks, TS
