jnoel64
I should know this, but I don't and searching through the threads is taking too long. In a dual rec, should both 5U4GB tubes be replaced together?
jnoel64 said:I should know this, but I don't and searching through the threads is taking too long. In a dual rec, should both 5U4GB tubes be replaced together?
Authorized Boogie said:jnoel64 said:I should know this, but I don't and searching through the threads is taking too long. In a dual rec, should both 5U4GB tubes be replaced together?
Rectifier tubes only need to be replaced when failing. They do not need to be changed at the same time. Thanks!
Enter your email address to join:
