As bendo pointed out, if the amp was in standby, no high voltage was applied to the tubes, so the tubes never saw any Plate current and they don't know where the bias switch was. Only the normal 6.3 volts was applied to the tubes' heaters, which is always the same voltage regardless of the bias switch. You should have no problems. 8)
