Hi, ist time on board. I have a Boogie MKIV. I have just purchased a Pod HD500 . Can anyone tell me can the preamp be bypassed using just the pod and boogie power amp. Many thanks in advance JIm
Look on the back for a power amp in or you can use the return of the effects loop. Both will bypass the preamp, and most likely the EQ section as well.
