I've read this thead and this thread from beginning to end.
Can I technically double the width of a TL806 and make a 212 Thiele cabinet? Loaded with two EVM12L's of course. I notices that the 412 cabinet has four times the volume of the 112 so I think this would work, but I want to make sure.
I have a Mark IV combo by the way.
I would have to wire it "weird" I guess. Since 12Ls are 8 ohms, I think there are a few options as to how I could run them. Please tell me if I'm correct. I want to run the combo speaker (8 OHMS) with it.
I could run them both separately and plug both speakers into the 4OHM jacks. The combo speaker stays in the 8 OHM jack.
I could wire them in parallel and plug the cab into a 4 OHM jack. The combo speaker stays in the 8 OHM jack.
I could wire the speakers in series while in parallel with a dummy 16 ohm load, and plug the cab and combo speaker into the 4OHM jacks.
I can probably also figure out a switch to be able to change between the second and third option.
I plan on making this with a metal grill and out of baltic birch or some other super durable plywood. I don't want to have to haul this in a case, so instead of tolex I'll use that stuff that Vader cabinets use, the stuff used on truck beds.
Thanks for any help guys!
