yellowjackets in heartbreaker?
nomadlover
has anyone tried this. i plan on using two 6l6s on the right and 2 yellowjackets on the left (maybe). a pal in the sd forums came up with this. how does this sound. what this bring the wattage down to on the halfcut and the full power? what 6l6s should i use to get a versatile sound that can go from red hot chili peppers to funk to black sabbath to jazz (relaltively)
you could run just 2 6v6 if you wanted the power REALLY down. just need to make sure the bias and variac is set correctly. heck, you could do 2 6v6 and 2 el84, or 2 el84 and 2 el34...theres alot of options for running tubes in this amp.
nomadlover said:
so do the tubes come with the yellowjackets or do i have to buy separately?
When you order the set of Yellowjackets (make sure you get the right ones, they have a few sets...), they come with JJ EL84 tubes.
