212Mavguy
Just got this in today. Check out ebay search 280352662220
Phenomenal machine. Could be considered a Hiwatt tribute amp with a couple of original twists. I can't post clips, but this is the second amp I have gotten from this custom builder using Bendix tubes. Big. bold, tight as can be, and the sonic detail is unreal, cleans sound like a Steinway piano! Even in class ab bias it puts out some amazing even order harmonics, which push pull amps have some difficulty doing normally, the output transformer is huge. Great tone stack, and not a one trick pony. Has bias and bias balance between each power tube adjustment pots.
Great silkscreened note on the back of the chassis: "This amp was designed to kick *** and take names but be warned that it contains lethal voltages that will ruin your day if you carelessly poke around in it!" "In memory of Dave Reeves and Harry Joyce, builders of some of the finest tone machines ever concieved." This amp IMHO takes their ideas to a new level by designing the output section around the 6384, a secret weapon amp tube if there ever was one. Bendix 6384's are designed to withstand 300g's, and last 10,000 hours. Their tones are simply amazing. Bendix tubes were designed for Cold War military weapons such as nuke missiles and B-52 bombers.
The other amp uses a pair of Bendix 6094's and it is biased to put out 18 watts, easily the stoutest sounding 18 watter I have ever heard. Also has bias and bias balance pots. Both are one of a kind customs that the builder made just for the love of the art of amp building. The builder used to work on Titan nuclear ICBM's and that type of overly stout cold war build exists in both examples. There are currently no pics on his site of the 6094 custom, top secret!
Great looking headshell, huh?
