Single Rectifier Solo series 2 - No sound!
antunififi
There's no sound coming on my Single Rectifier. Checked all the cables and plugs but its just a small hum coming out from the speaker.
Could this be a preamp tube problem?
Is this a new amp? Have you had it for a while working and now it doesn't work? Did you change anything recently?
bought it used. it was ok the last time i used it then when i turned it on, theres no sound coming in CH1 and very low sound from CH2.
I didnt do anything since the last time I used it.
This most certainly sounds like a preamp tube issue. Swap a new tube in, one position at a time. I would suspect V3 or V1, but anything is possible. Avoid EH, Sovtek, Tung-Sol reissue, Mullard reissue & Mesa "Russian-1" (Sovtek) & "Russian-2" (EH) tubes in V3 & V4, they have been known to fail in those positions. JJ's, any Chinese, and the latest Mesa 12AX7 (JJ) are fine.
Dom
Dom
Mesa Russian 2 is currently installed right now.
Just ordered a Mesa 12AX7 from sweetwater, just waiting for it to arrive. Hope its just a preamp tube.
Will update you once I get the new tubes.
Thanks Dom!
Preamp tubes was the problem. Changed them all, everything sounds great now!
Thanks for the help everyone
