Quad preamp tube experiment with pics of gear
jonamojo
orange county, CA
I have quite an assortment of NOS and newer 12AX7's , so I thought I'd post the results I found. I played through a 1957 custom shop heavy relic, and a 1952 tele reissue with a humbucker in the neck ala keith style. So mind you , my final choices may not work for you if you are using a les paul or something else with a humbucker in the bridge.
these are the tubes tested
sovtek 12AX7WA
JJ ECC83S
Tungsol 12ax7 reissue
Mesa boogie STR 12ax7-A smooth tall grey plates made in yugo look like telefunken's
Jan phillips 12ax7 NOS made in 1987
Mullard I63 NOS short plates
GE 12ax7 short plate used
GE 12ax7 long plate used
Sylvania long plate 1957 used halo getter
Sylvania short plate NOS 1950's D getter
Telefunken 12ax7/ECC83 tall smooth plates
Amperex 12ax7/ecc83 bugle boys I6?/delta 2I1 NOS small halo getter
Amperex12ax7/ecc83 I66/delta 4H3
EI grey plates, same tube as the old mesa's
sovtek 12ax7lps 3 from 1999
I stuck the sovtek lps's in the effects send and the reverb return for all tests.
My power amp is a mesa 50/50 with NOS mullard in V1 and telefunken NOS smooth plates in both PI positions.
Channel A drives a pair of Groove Tubes 6L6GE's
channel B drives a pair of Sylvania Str-415's NOS
So, here we go the sovtek 12ax7wa is a decent tube though rather plain,not much gain and a little treblely. pretty sturdy no microphonics and low noise.
The jj ecc83s was harsh to the bone. I have 7 of these so I tied different ones, but in every position they lacked character, remember I'm playing through a strat. On the bridge pickup they sound thin, with no body these were easily the worst in my opinion.
The tungsol reissue's performed quite well,nice bottom end, good mids, decent highs. They sounded similar to the jan phillips but not quite as well rounded.
The sylvania long plate sounded bold chime nice gain with buttery top end.
The sylvania short plates had a beautiful range with nothing accentuated smooth lows plump mids buttery top.
The telefunken smooth plate sounded great anywhere beautiful tone low noise more mids then the americans less top end.
The amperex have less gain then the rest of these tubes and since I'm running pickups with relatively low ohm's they didn't perform so well. Though I will say in V1 nothing sparkled like these.
The GE tall plate was used and had a slight hum other wise it was balanced with a full sound nice lows round mids smooth top
The GE short plate faired alot better low noise somewhat subdued lows strong mids subdued top real close to a real mullard.
The mullard I63's had a nice bottom plump mids and somewhat reserved top end very low noise with lots of gain, growling gain no fizz here
The Ei tall grey plates made in yugo are a copy of the tele's, they have more gain but are not as detailed or defined but were head and shoulders above the jj's and the sovteks, and the tungsols.
So, this is how it worked out
1 clean channel=sylvania short plate
2 dirty channel=mullard I63
3 Lead channel 1=telefunken smooth plate
4 lead channel 2 EI grey plate
anyways happy new year to all :p
I was unable to test my rca 12ax7 black and short plates because they all reside in my 74 twin reverb where there staying!! I'm pretty sure they would have scored a high mark too...regards....J
It would be interesting to know how well Mesa tubes compare to all the others you tested. My Quad is loaded with all Mesa tubes.
I tested two mesa str12ax7 but they were from the early 90's they were actually built in a factory in the old yugoslavia the old EI factory before it was lost in the war, They cost a pretty penny now on ebay the two I had had wonderful gain thick mids real close to the telefunken smooth plates however they both suffered from microphonics. I might add I spent an hour listening to each tube subsituiting positions. If I had to buy new tubes I would buy all tungsol reissue and sovtekLPS. And those later model jan phillips NOS can be found for about the same price and they last forever. again remember I"m playing threw a 2011 1957 fender customshop heavy relic. My selection might not work for your les paul/jackson/prs
Feel real lucky to own this pedal wonderous with the twin
mojo cab in snakeskin scumback H55/H75 in series, 50/50 pweramp I only use one side
NOS RCA 12at7 for reverb send Sovtek LPS 1999 return
Sovtek LPS 2000 for the loop
I stick the cheap stuff in places I can get away with it, there isn't any need to have mullards and amperex's in the loop, thats my opinion acorrding to my ears and as you know we all have a different pair.
