MKIIC+ volume drop changing channels
zodiac272
NE Philly
hey,
do the loop test on it and you will know if it's a "+"
I think on my C+'s there is a very slight volume swell when footswitching lead to clean, but it's instant from clean to lead. Both of mine were just serviced at the mesa factory, so i'm guessing it's fairly common with those amps
I'll check it out again later to be sure
scott
"when changing from lead channel to clean there is a slight delay in the clean channel coming up to its correct volume"
I have the same thing. It's normal. If it's takes a couple of seconds that is not normal and could be a faulty LDR.
