Mk V and G-Major
General troubleshooting:
Double check your wiring and make sure your insert cable is connected to the correct jacks
Try switching the Channel two and Channel 3 cables and see if you can only switch between Channel 1 & 2.
If that works, double check your relay setting in the G-Major. There will be four possible settings:
Relay 1: Open
Relay 2: Open
This should result in Channel 1 being active
Relay 1: Closed
Relay 2: Open
This should result in Channel 2 or 3 being active
Relay 1: Open
Relay 2: Closed
This should result in Channel 2 or 3 being active, which ever wasn't active with the previous combination.
Relay 1: Closed
Relay 2: Closed
Don't use this combination... it will attempt to activate both Channels 2 & 3 simultaneously.
So, I tripled checked everything and it still will only switch between 1 and 3. I have a TRS stereo to Y stereo.
