Mark V:25 Microphonic noise - HELP!
VoronArgentum
Just got my MarkV:25, and have two questions:
1. I got a very loud microphonic noise when I turn gaine and treble at 2:30 - 3 o'clock and the volume at noon. Does your MarkV:25 got the same problem or I've a bad luck?
Yes I read in the manual that Mesa advise do not use extreme settings with loud volume. but it's not so extreme. I mean it's not all the way up! Really confused about it
2. Is your fans loud as hell or I've got a broken one? I remember that it was able to turn it off in MarkV but here it is all time on and quite loud. Very loud! :(
Any help is really appreciated!
My fan is pretty quiet as well. See if it spins by hand freely, without any noise or resistance. Possible it's a bad fan, but will is under warranty. Probably swap-able by you with basic tools if Mesa will ship you a new fan.
As for the microphonics, it's either a tube or you need to dial back the treble a bit. I wasn't having issues with mine, but I have since replaced the factory pre's with the SPAX7s because I wanted to put them in all slots. I also don't need the treble above noon to get what I need. Try dialing back the treble on the knob, but add back what you need on the GEQ or presence knob.
I will change this head tuesday in local store, already talk to my friend (because it's his store :lol: )
So we will look at this and compare with another head tuesday.
Can you guys tell me/point me in the right direction of how I would go to change preamp tubes...where would be the best place to start with taking per-installed tubes out for replacement. I have a Mk5-25 and am thinking of replacing tubes. It's pretty cramped in back of Mk5-25 for my hands...what do I start to take out first.
Cheers.
Tried 3 different Mark V:25 and they are all squeals at some point. So I choose one that is more stable and have quite fan :)
Demo arrive soon!!! :)
Cheers.
I think you need to take out chassis by removing 4 top screws or maybe removing the front panel. I don't open mine for the moment :)
