Mark V:25 FX send/return
Kavevester
On other gear (Axe FX2) the send/return has to be chosen in setup and if so there needs to be a signal way (have to connect something from send to return)
How dos it work on this amp? is send/return mixed in parrallel to the signal in the amp or dos the connection open up the signal chain and letting the send/return
be active when plugging in or?????
The send/return jacks are switching jacks. When nothing is plugged into the FX loop it is internally connected send to return so no patch cable is needed.
As soon as you plug into the fx loop this internal connection is broken.
Dom
