Major volume differences clean channel MV-35
Tonehound
Can't get over and wondering if this is normal while in clean channel. If I'm set on Crunch and adjust amp, then try cutting neck to either Fat or Clean the volume drops which seems more than 1/2. I typically run off the 10watt mode and while using crunch volume could be say around 9oclock, then switch to fat or clean I pretty well need to dime volume to get anywhere near same volume.
Is this just my particular amp or they all like this.
Thank You.
